ML-9600
COTS 1.7-30 MHZ 100W MODERNIZED HF WIDEBAND TRANSCEIVER
ML-9600 — Modular Wideband HF Platform for Custom or External Waveforms
FlexRadio’s ML-9600 wideband Software Defined Radio delivers the same high-dynamic-range HF architecture and ultra-low-phase-noise performance as the ML-9600X—without the integrated modem suite. Designed for military, government, commercial, and research customers who rely on external modems, government-furnished waveforms, or proprietary DSP, the ML-9600 provides a clean, modern RF platform supporting 78 kHz transmit and up to 1.2 MHz receive bandwidth, enabling next-generation wideband HF waveforms and high-speed data transport when paired with customer-selected processing hardware.
With IP-based Ethernet control, the ML-9600 integrates easily into fixed, mobile, and distributed systems via the included Windows client or the open SmartSDR™ API. The API supports plain-language command/control, VITA-49 RF/IF/FFT streaming, and flexible integration into R&D toolchains including GNU Radio. Optional precision time-stamping, support for diversity reception, and dual +10 dBm exciter outputs enhance system-level versatility for labs, integrators, and OEM waveform developers. When paired with FlexRadio’s high-power amplifier family, the ML-9600 becomes a scalable, standards-ready wideband HF transceiver that preserves full control of external modem and waveform processing.
Download PDF.
FlexRadio’s MLS-9601 1 Kilowatt Wideband SDR Communications System.
FlexRadio’s MLS-9605 5 Kilowatt Wideband SDR Communications System.
FlexRadio’s ML-9600X 100W SDR transceiver with waveform suite and ALE
What People Are Saying
I made a couple of contacts and realized ham radio with FlexRadio is more than it had been before!
Larry, K9OQ
Contact Us Today
If you require assistance with an existing product, please contact us today.
The only thing that can match our high-quality equipment is our equally high-quality customer service. Please drop us a line, and we’ll be in touch.
Send Us a Message
10 + 5 =
