Military Solutions
Our experience in Software Defined Radio extends across every domain.
Whether your mission involves ISR, geolocation, real-time signal analysis, or high-density digitization and transport of satellite and terrestrial IF signals, FlexRadio’s open-architecture SDR platforms provide the performance and flexibility to meet evolving operational needs.
Transceivers
ML-9600X — Open-Architecture, High-Performance Wideband HF
The ML-9600X delivers next-generation wideband HF performance in a fully open, modular SDR architecture. Engineered for modernized military and government missions, it combines ultra-low phase noise, wide bandwidth, and a full MIL-STD/NATO modem suite with open APIs and VITA-49 for seamless integration into advanced communications and ISR systems.
Key Capabilities
- Full MIL-STD & NATO waveform suite including 2G/3G/4G ALE
78 kHz TX / 1.2 MHz RX wideband HF architecture for modern waveforms - High-speed HF data up to 240 kbps
- Ultra-low phase noise for demanding EW/ISR missions
VIEW PRODUCT
ML-9600 — Modular Wideband HF Platform for Custom or External Waveforms
The ML-9600 provides the high-performance wideband HF foundation of the ML-9600X in a modem-ready configuration optimized for customers who supply their own MIL-STD modems or develop proprietary waveforms. Ideal for military programs, integrators, labs, and system developers, it offers wide bandwidth, ultra-low phase noise, and an open SDR architecture at a reduced cost. With optional onboard waveform processing modules and full VITA-49 support, the ML-9600 enables rapid prototyping, specialized mission profiles, and seamless integration into modern HF systems.
Key Capabilities
- Same wideband HF architecture and performance as the ML-9600X
- Designed for external modems or custom waveform deployments
- 78 kHz TX / 1.2 MHz RX bandwidth for next-generation HF waveforms
- High dynamic range and ultra-low phase noise for advanced missions
- Open API + VITA-49 streaming for complete control and integration
VIEW PRODUCT
High Power Systems
MLS-9601 — High-Power, Mission-Ready Wideband HF System
The MLS-9601 combines the ML-9600X wideband HF transceiver with a rugged 1 kW power amplifier, integrated coaxial and Ethernet switching, and a unified power system—delivering a complete, ready-to-deploy wideband HF solution. Built for demanding government, defense, and commercial environments, the MLS-9601 provides exceptional RF performance, resilient high-power operation, and seamless integration through open standards, while automatically falling back to the ML-9600X’s internal 100 W PA to maintain communications in the unlikely event of amplifier fault conditions.
Key Capabilities
- Integrated 1 kW wideband HF system with automatic failover to 100 W
- Open API + VITA-49 for advanced integration and remote operation
- Precision timing, diversity reception, and real-time spectrum displays
- Engineered for long-range, high-reliability HF in mission-critical deployments
VIEW PRODUCT
MLS-9605 — High-Power, Wideband 5 kW HF System
The MLS-9605 delivers extreme-range wideband HF performance using four 1.5 kW amplifier modules combined under a unified system controller. Designed for demanding military and government missions, the MLS-9605 provides a full 5 kW of output power while maintaining API-level compatibility with the MLS-9601—enabling effortless upgrades, simplified integration, and common software control across power levels.
Key Capabilities
- Unified system controller presents a single, common API—identical to the MLS-9601—for seamless integration
- 5 kW high-duty-cycle architecture using four rugged 1.5 kW amplifier modules
- Extended HF reach for extreme-range, poor-propagation, and contested-spectrum environments
- High-power wideband performance supporting voice, data, ISR, and EW missions
- Open API + VITA-49 for advanced system integration and multi-domain interoperability
VIEW PRODUCT
MLS-9610, MLS-9620, MLS-9640
Need even more power? FlexRadio provides scalable wideband HF solutions of 10 kW, 20 kW, 40 kW, or more.
Reach out today to explore a system engineered for your mission.
Specifications |
CL-9300 |
CLS-9301 |
ML-9600 |
ML-9600X |
MLS-9601 |
| MIL-STD-188-110 Bandwidth | − | − | − | 48 kHz | 48 kHz |
| Max TX Bandwidth | 3 kHz | 3 kHz | 78 kHz | 78 kHz | 78 kHz |
| Power Output | 100W | 1000W | 100W | 100W | 1000W |
| Maximum Receive Bandwidth | 192ksps / 150kHz | 192ksps / 150kHz | 1.536Msps / 922kHz | 1.536Msps / 922kHz | 1.536Msps / 922kHz |
| Waveform Porting Kit and Module | − | − | − | Ο | Ο |
| GPSDO | Ο | Ο | √ | √ | √ |
| Precision Time- Stamping | − | − | Ο | Ο | Ο |
| SCU | 2 | 2 | 2 | 2 | 2 |
| RX | 4 | 4 | 4 | 4 | 4 |
Specifications |
CL-9300 |
| GPSDO | Ο |
| SCU | 2 |
| RX | 4 |
Specifications |
CLS-9301 |
| Power Output | 1000W |
| GPSDO | Ο |
| SCU | 2 |
Specifications |
ML-9600 |
| Max TX Bandwidth | 78 kHz |
| Receive Bandwidth | 1.536Msps / 922kHz |
| GPSDO | √ |
| Precision Time- Stamping | Ο |
| SCU | 2 |
| RX | 4 |
Specifications |
ML-9600X |
| MIL-STD-188-110 Bandwidth | 48 kHz |
| Waveform Porting Kit and Module | Ο |
| GPSDO | √ |
| SCU | 2 |
| RX | 4 |
Specifications |
MLS-9601 |
| GPSDO | √ |
| SCU | 2 |
| RX | 4 |
Optional Accessories
Waveform Support Processor
FlexRadio’s optional waveform processor provides a dedicated, high-performance compute environment for mission-specific signal processing and custom waveform execution. Built around a quad-core ARM Cortex-A72 running at 1.5 GHz, this standalone module isolates user applications from the main radio architecture, ensuring secure, predictable, real-time performance. Customer-developed waveforms run inside a Docker containerized framework, offering a modern, portable, and easily maintainable deployment model. This approach gives integrators and mission developers the freedom to innovate—executing advanced or proprietary waveforms directly within the ML-9600 series hardware while preserving full interoperability with standard APIs and radio control interfaces.
Waveform Development and Porting Kit
The ML-9600 Waveform Porting Kit accelerates the transition of customer-developed waveforms from concept to fully integrated, on-radio execution. Providing a complete toolchain—including cross-compilers, documentation, templates, and working examples—the kit enables rapid adaptation and optimization of mission-specific waveforms for the ML-9600 series radios equipped with the optional waveform processor. Developers can build and debug their applications on external PCs using familiar workflows, then seamlessly cross-compile and deploy them into containerized environments on the radio. This flexible development path shortens integration timelines and empowers organizations to field new capabilities quickly while preserving the reliability and security of a managed SDR platform.
Contact Us Today
The only thing that can match our high-quality equipment is our equally high-quality customer service.
Please drop us a line, and we’ll be in touch.
