Commercial Series
Seamless HF connectivity for critical commercial operations.
Our 100 W–10 kW wideband HF systems support modern and legacy standards, enabling resilient communications for industry, emergency preparedness, and coastal and maritime networks.
Transceivers
CL-9300 — Next-Generation Commercial HF Communications
The CL-9300 is a modern software-defined HF transceiver designed for reliable long-range communication in commercial, emergency-management, and critical-infrastructure environments. With an open architecture, advanced DSP core, and seamless interoperability with government and emergency networks, the CL-9300 delivers dependable voice and data links for organizations that require always-available communications without the cost or complexity of legacy HF systems.
Key Capabilities
    • High-reliability HF communications for EOCs, utilities, disaster response, and critical infrastructure
    • Open architecture for flexible integration with government and commercial networks
    • Advanced DSP engine for exceptional clarity and long-range performance
    • Ideal for fixed-site installations including maritime shore stations, industrial facilities, and remote field offices
    • Cost-effective, continuously available communications—independent of satellite or terrestrial infrastructure
VIEW PRODUCT
CLS-9301 — High-Power HF System for Wide-Area Connectivity
The CLS-9301 pairs the CL-9300 SDR with the 1 kW FPA-1K amplifier to create a high-performance HF communication system optimized for long-range, fixed-site operations. Designed to deliver dependable coverage across wide geographic areas, the CLS-9301 supports configurations such as split-site TX/RX deployments and multi-location networking—ideal for building resilient HF links for government agencies, emergency-management centers, maritime shore stations, and commercial operations requiring always-available long-haul communication.
Key Capabilities
    • 1 kW HF system combining CL-9300 SDR + FPA-1K amplifier
    • Long-range performance for wide-area and global connectivity
    • Supports split-site and distributed HF architectures
    • Reliable voice/data links when other systems are unavailable
    • Flexible deployment options with proven HF performance
VIEW PRODUCT
High Power Systems
CLS-9305 — 5kW Global HF Communication System
The CLS-9305 delivers extreme long-range HF performance with a modular 5 kW architecture engineered for resilient, wide-area communications. Built on the same advanced platform as the CL-9300 series, it provides exceptional signal penetration, high-clarity operation, and the power margin required for large-scale HF networks spanning continents and oceans. Ideal for fixed-site, split-site, and networked deployments, the CLS-9305 ensures reliable connectivity where maximum range and non-stop availability are critical.
Key Capabilities
    • 5 kW high-power HF system for long-haul, wide-area communication
    • Exceptional coverage and signal penetration for challenging propagation environments
    • Supports large HF networks with high reliability and continuous duty performance
    • Compatible with CL-9300-series architectures for streamlined integration and operation
    • Ideal for strategic communications, maritime networks, and fixed-site infrastructure
VIEW PRODUCT
need even more power?
FlexRadio’s modular wideband HF architecture scales effortlessly beyond 5 kW. Our high-density amplifier modules and unified system controller allow the same core platform to expand to 10 kW, 20 kW, 40 kW, or higher, all while maintaining a consistent API, control interface, and waveform capability. Whether your mission requires extreme-range communications, penetrating difficult propagation environments, or supporting wide-area HF networks across continents and oceans, FlexRadio can engineer a system sized precisely to your operational demands.
Specifications
CL-9300
CLS-9301
ML-9600
ML-9600X
MLS-9601
MIL-STD-188-110 Bandwidth     − 48 kHz 48 kHz
Max TX Bandwidth  3 kHz 3 kHz 78 kHz 78 kHz 78 kHz
Power Output 100W 1000W 100W 100W 1000W
Maximum Receive Bandwidth 192ksps / 150kHz 192ksps / 150kHz 1.536Msps / 922kHz 1.536Msps / 922kHz 1.536Msps / 922kHz
Waveform Porting Kit and Module     −    −   Ο   Ο
GPSDO     Ο Ο     √    √    √
Precision Time- Stamping      −  −    Ο Ο Ο
SCU    2 2 2 2 2
RX    4  4 4 4 4
Specifications
CL-9300
Power Output 100W
GPSDO     Ο
SCU    2
RX    4
Specifications
CLS-9301
Power Output 1000W
GPSDO Ο
SCU 2
Specifications
ML-9600
Max TX Bandwidth 78 kHz
Power Output 100W
Receive Bandwidth 1.536Msps / 922kHz
GPSDO     √
Precision Time- Stamping    Ο
SCU 2
RX 4
Specifications
ML-9600X
MIL-STD-188-110 Bandwidth 48 kHz
Power Output 100W
Waveform Porting Kit and Module   Ο
GPSDO    √
SCU 2
RX 4
Specifications
MLS-9601
Power Output 1000W
GPSDO    √
SCU 2
RX 4
Contact Us Today
The only thing that can match our high-quality equipment is our equally high-quality customer service.
Please drop us a line, and we’ll be in touch.
